Darius »
https://forums.nicoclub.com/darius-u5470.html
Thu Jan 17, 2013 6:50 pm
What you are doing is called a boost leak test. A leak down test measures the amount of air leaking past the rings or valve seats when all valves are closed.
Get a spray bottle and put some dilute soapy water in it and spray it at any possible point for leaks. Couplers, BOV flange, fitting, etc. Another method is to use a propane torch and do the same thing, but obviously don't light it. If the engine is running and the idle increases as you apply propane, then it has a leak.
And you can click a box to have your search results be returned as titles before you hit go.
