sumyungye wrote:now this may be a noob question... but what is the difference between painting it like this and getting the overlays
Paint is cheeper and easier to apply. It also looks better in my opinion. Well if it is done right. I have seen some that look discusting and I have some that look good. It all depends on the look you are going for. Paint will generally come out darker and you can make it glossy or matte. But overlays are much easier to use and you can see the brake lights alot better because of it.
Marisha wrote:Now I haven't done either but as I see it...paint is permanent vs. you can peel the overlays off. On the other hand, paint's probably cheaper and easier to do yourself than overlays.
If you use the paint that I used then paint is not permanent. It can be taken off with nail polish remover and some scrubing. I don't know if you can remove the other types of tinting paint thats out there, but I know some of them require sanding. So that would be permanent.
