le_ryan »
https://forums.nicoclub.com/le-ryan-u30337.html
Sat Mar 24, 2007 6:52 pm
I had to redo this since the pics were all deleted, while i was at it, i rewrote it to make sense and corrected ALOT of spelling, also added a few better pics.
Tired of that uncomfortable plastic armrest? Not anymore ..
oh so soft now..
Here's how i did it.
1. Get your self some:- foam of your choice (fabric store) the stuff i used is a very firm type of foam, and is only and inch and a half thick- vinyl, leather, or material of your choice ($10.oo per yard at a fabric store)- Razor blade- office stapler, or an actual staple gun, but use only 1/4 inch staples or they will go through.- A heat gun or a hairdryer work too
2. Pull off your arm rest by removing the two screws at the bottom holding the hinge on. and wiggle the arch out carefully.
3. Remove all the screws, including the one hiding under the latch.
4. Trace the top of the lid with against the foam, give yourself about a half inch extra on all sides, you will be trimming some off later on .
5. Cut it out, then trim it at an angle, with a downward slope, your razor needs to be sharp for this. You dont have to trim it off at an angle but, it looks nice under the vinyl if you do..
6. place it on top of the lid now, and make sure theirs not any hanging over the edge, any protruding bumps or deep grooves will show through the vinyl, so cut it at clean as you can,.
7. Lay the foam and the lid down onto the vinyl, and cut an over sized square around the lid, to make it easy to work with.
8. now fold the vinyl up to the edge, and roughly measure an inch to two over the edge, what your doing is cutting enough to fold, and stretch into the lid so that you can staple it in there, later you will trim off the extra.
9. I have no pics of this part because i only had two hands .. Once you have cut your pattern out, you can begin the folding and stretching process.What you do is gently heat one side up, pull it into the lid, and staple it in, then go to the opposite side and do the same, then the other, and the the remaining side.Once you have a staple in all sides, work your way around heating and stretching the material into the lid and stapling it in.It wont look like its gonna work at first, dont be discuraged, It will work and the payoff is sooo nice.
When you have it all nicely stretched and stapled in and your satisfied with the look, screw the liner back on, this adds more strength to holding the vinyl together, as you can see.
Re-install the armrest into the car, and admire your own handy work.Black vinyl matches almost perfectly, see you cant even tell, you can use any material you want..
Modified by happy240 at 5:32 PM 3/26/2007
