I threw my KA parts away cept for my harness that I use wires from and clips .Andrew85cm wrote:Check your pile of KA parts I found my thing to mount my probe in the left over parts from the KA and it works great. Then I just took it to Home Depot and got the fittings I needed and jerry rigged some stuff.
The water temp prob for the factory gauge? Use the KA one if your running the KA cluster.Sil240 wrote:hey will the SOHC KA water temp probe work with the RB20 ecu?? Or should i just use that little metal tube again but with the skyline sensor
