How to mount 7 pin trailer plug on 2005 Xterra
akira69
Car: 2005 Xterra 4x4 SE Manual
I bought a hidden hitch tow hitch, and the Nissan 7 pin tow harness.
However, there's no place to mount the tow harness! The install instructions show a nice metal block where the harness is supposed to go. I guess that the hidden hitch doesn't include it, but the OEM does.
so, where did you guys mount the plug? How did you do it?
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
You may need to splice it in one wire at a time.
I thought the Xterra only had a 4 pin adapter plug at the back...At least the 2000-2001 had that from the factory.
I don't have the latest info on the current Xterra/Frontier systems. I wonder if NM50 might be able to help here...
OH NM50????
Encryptshun
Car: 2005 Nissan Xterra
The 2005 does have a 7-pin plug -- you'll need a 4-pin adapter to get it to work with most trailers.
Mine already had everything installed when I bought it. I'll look at my set-up tonight and let you know what I find tomorrow.
akira69
OK Fellas, I got this done...
First I cut the hole with a 2 1/8" bimetal hole saw about 1 1/16" above the plastic of the license plate light.
Then I primered and rust-oleum painted the hole
Cut off the excess crap from the plug
Drilled the mounting holes and primered and rust-oleum painted those too. Then mounted the plug and sealed it all up with silicone
Done! Thanks guys for your help.
Encryptshun
Very nice work!
btw--I got my Xterra at Woodfield Nissan as well.
