schuylkill »
https://forums.nicoclub.com/schuylkill-u299830.html
Tue May 18, 2021 3:42 am
So the previous owner of this 2004 SE messed with the coils and he did a sloppy job. There are no clips for attaching coil wires to the tabs on the cover. Do the wires sit in front of the tabs or behind when looking from front of the van? Where do the other wire sit to fit properly under the intake? He also used a straight hose to connected to the pvc valve and it was kinked and pinched to form into an elbow which essentially blocked it. Where does the bracket that is attached to the silver covered bundle in about center of photo get anchored? If anyone has an image of this arrangement I would appreciate it.
