hokiruu »
https://forums.nicoclub.com/hokiruu-u3429.html
Thu Jan 30, 2003 6:38 pm
I know a guy with an s14 who swapped in an s15. It was a big pain in the as* to do and cost tons of money and took forever. I took a ride in it and yes, it was pretty damn quick. But his tach, spedometer, and VTC all didn't work at all, among other little annoying problems. To make all that stuff work I guess you need to have the ECU retuned by Jim Wolf or something, at least for the VTC. The spedometer uses a completely different type of signal, so it is incompatible with the s14, at least that's what he told me. It might not be the same for everyone, but that's all what he told me and I saw. It is probably pushing at least 325hp with the stock t28 turbo. Guess what though? He still wants to upgrade the turbo. In his case, he probably would have been better off building up from an s13! So it sounds like you first need to figure out what you want, and what you can afford. Sure, the s15 swap has alot of "cool factor" appeal, but it might not be worth it. If you ask me, I'd say just buy an s13 and upgrade the turbo, even if it is only to the s15 t28 bb turbo ($8-900). The beauty of the s13 is that you can rebuild the turbo to bigger specs for relatively cheap, and you can't do that on the later models because they are ball bearing center section turbos. Or if you have the cash, get a bigger turbo, but you need some other stuff to go with that for fuel and a few other engine parts. BTW the seemingly desireable 6 speed transmission from the s15 is supposedly not as strong as the older 5 speeds, as Japanese s15 drivers seem to be swapping to this transmission.
