MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Fri Feb 22, 2008 2:37 am
If you have the ABS light, you should have ABS. Without ABS, the spot for the light would still be there, but it wouldn't illuminate.
If you want to double-check, though, you can look for the ABS actuator under the hood.
In case the image isn't clear, it's just inside the driver side strut housing. It has vacuum lines coming out the front and top.
