AmoebAssassin wrote:If you get a non-recirc BOV you risk stalling on decelleration
Raise your base idle to about 900 RPM and it won't happen.
AmoebAssassin wrote:poor fuel economy
It's impossible for the engine to get worse gas milage. Anyone who says otherwise is a victim of placebo, or self-induced granny driving because they don't push the throttle to hear the BOV.
AmoebAssassin wrote: constant backfiring between shifts which could eventually lead to turbine damage and catalytic converter damage
The mixture does not ignite until it mixes with the air at the exhaust exit. At least in a maintained vehicle it doesn't. If you have 10 exhaust leaks and don't take care of your car then yes, you can have backfiring in the exhaust tract. It definately does not damage the turbine, as that would cause excessive boost spiking as a side result.
