How To: Make clear third brake light on s13 vert/coupe
94_240sx
Car: 94_240SX
I didn't like the first one that I made last year, so I made some improvement on this version.
This is the hardest part. You need to remove the red lense without damaging other parts. Bake method didn't work, but a heat gun worked pretty well. I pryed the red lense out as it melted by heat gun. You need a valance which is located right underneath the lense, so don't damage it. I didn't use valance when I made the first version and lighting was terrible. Outer edge is not clean as you can see in below picture, but it's okay because clear lense will cover it.
Fluorescent light cover that I bought from Home Depot. As you can see I used the side portion.
Here's the fitment on OE light. There's a gap.
I used a Dremel to cut and shape it.
Here's mine. It fits perfectly like this. Take your time and trim the sides slowly.
I just used double sided tape to attach the lense to the valance.
Of course, you need a red LED bulb.
Red lense was slightly thicker than new clear lense, so I used washers in the back to push it out a little. I tried two washers on each side and it pushed out a little too much.
Done.
When it's on.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
Guess where I'm going right now
biggie
Thought of getting LED strip to make it span the full width? Or would it not fit?
94_240sx
Car: 94_240SX
biggie wrote:Thought of getting LED strip to make it span the full width? Or would it not fit?
I don't want it too bright, so... Besides, I've never worked with LEDs.
Hijacker
Car: '92 240sx Convertible
'94 F-150
It looks a bit dim to me in that second pic. Probably cause it's in the daylight. But you can never be too bright on a third stop lamp, IMO.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
nice. great work. Looks stock.
