sicride »
https://forums.nicoclub.com/sicride-u39254.html
Sun Mar 18, 2007 1:34 pm
don't know if you'll ever see this post since it's been so long since your original.
The Z31 is really not made up to go 1/4 very fast especially NA. What are your current times? and what are you looking to be at?
I would imagine if price is not an option, N2O is the way to go (you can still use NOS if you prefer that company but there are many other options out there). From what I've seen of Z31's on a launch they squat like crazy. This isn't a bad thing; the bad thing is how the suspension does this, it creates a ton of negative camber and kills your contact patch. If it is a track only car and you mean drag only car, then I would look into a drag alignment. Also does the car have a limited slip differential? Horsepower is only 1/3 of what the car needs to perform.. Equally important is the driver and traction. You can find atleast .8 seconds in a 1/4 from traction alone on almost any car, I can't imagine the Z31 would be any different.
I know very little about Z31's so this is just general knowledge for the most part.
