How to lower your drag coefficient?
Want to talk about non-Nissan cars? Here's the place!
sanioll
Car: Nissan 240SX SE
Toyota Camry
so how? yes we all can get technical, reengineer the whole body system of our vehicles, but do you know how many hours of testing calculating and actual lift, downforce experimentation will it take to make it safer at high speeds?
So we need some cheaper, eaiser way to do it.
I came accross this 2 years ago, and its useful, it works.
For some this maybe really "old skool," but:
hit the button next to ac/heater to take the air into cabin from the outside. Turn off ac/heater obviously, and open your windows just a bit, just enough for the air to escape, is say 1/2 inch each window.
at anything higher than 80mph you will see the improvement in acceleration, and your top speed will increase too, DUHHH!
------------------------------------------------------------------------*note: make sure you recurculate air inthe cabin during the pollenation season. pollen clogs up your cabin filter and it stinks later on.
sanioll
Toyota Camry
its very nice especially if outside temp is below 30F.
Also slide heater all the way to heat max., so you can get warmer air blown into the cabin, since you may feel cold.
then shift to fourth gear and hit 80-100 mph.
Lexus has underside dimples, which are apparently useless.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
It's really interesting to see how small things impact drag. On the new Maxima, for example, the tiny lip spoiler makes a difference of .02 (.28 with .30 without). I didn't expect that much difference...it's not even two inches long. Of course, the A34 looks funny without the spoiler anyway...too round.
Rex
Car: None
Jesda wrote:Lexus has underside dimples, which are apparently useless.
^ Repost ^
<--jerk
sanioll
Toyota Camry
Dammit, this place is dead, dammit too many posts., i mean come on!
is it too cold for you all to get up your asses and test this thing at high speeds, and than come back and say, hey sanioll, thank you, it was very cool,. youre the man, genious, victorious, etc..
sigh...
Urabus GodofTraction
Car: 2002 Subaru WRX Wagon
2004 Suzuki SV650
1988 Toyota Land Cruiser
1994 Honda XR600R
Doesn't opening the windows add drag? If so, that would cancel out any gains.
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
Why can't you just spray some Teflon on the hood of your car and call it a day? If you are short some money this month, I am sure that PAM will work just as well to lower the drag co-efficient.bud
sanioll
Toyota Camry
i know, i know
i am totally
good one.
sanioll
Toyota Camry
charlieo wrote:Doesn't opening the windows add drag? If so, that would cancel out any gains.
yes, thats why you open them up just a little bit. less than 1/2"
Mr1der
I'm gonna make a car that looks like some kinda crazy *** spatula...
madmax88
Car: my car
use some lube.
Return to “Others”
