94_240sx »
https://forums.nicoclub.com/94-240sx-u26401.html
Mon Nov 17, 2008 5:32 am
I was cleaning up my desk and found a roll of sticker sheet that I used to create 'LIMITED EDITION' decal, so I decided to do this write up. You can go to any sign shop and ask for leftover white sticker sheet. Most likely, they will just give it to you. It's too much work for 'LIMITED EDITION,' so I'll just make something simple as an aexample. If you really want to have them, follow the process and make a set.
Use paper and pencil to trace old decal. This is driver's side. Note the angle. Passenger side and driver's side, they are NOT same.
This is passenger side. I just traced 'DIT' for my little project.
I used the template to design letters. Basically, you want same spacing, angles and stuff.
Cut the template and attach to the sticker sheet.
You are going to cut the lines carefully, and it'll come out like this. You don't want to cut it all the way down. You just want to cut the first layer, so they won't fall apart.
Put a piece of tape over to hold it together.
Flip it and you are going to remove portions that you don't want.
It's done, but I didn't like how '3' looked. It was too square, so I cut the corners. Now, it's ready to go on to the car.
Line up the letters and attach them. All done!!!
