If your car weighs less than 2 tons then you can use a 2-ton jack at any point on the vehicle and you shouldn't have to worry about damaging the jack. The load cannot be more than the weight of the vehicle, regardless of your lift point.cyrusyn wrote:Do you think a 2 ton trolley jack can lift under the frame rail without getting damaged? Stuff like a scissor jack sure will be damaged if lifting a spot close to the center of the gravity of the car.
240kid wrote:build little ramps for your car for an extra lift, only use them on the tires your lifting though. you can jack it on the pinch weld if you must, although i wouldnt recomend it. a normal jack will reach with plenty of room under the rear differential or the point up on front
