240Knightrider wrote:you have to play with your car and PRACTICE
Every 240 is different...ive owned three and they all launched different
One would lauch at 2000k with a pop of the clutcn, my white at 1400....my blue im still learning.
The best is to Pop the clutch without wheel hop and without spinning the tires.. You will have a much better time. And your launch will be awesome if you master that. It takes time and practice.
Start at 1k and pop the clutch and go...You will probably wheel hop and then go. Move up until you dont have wheel hop and the wheels dont spin.
This is true, I have a 240 with a 2JZ-GTE. 396rwhp and 411 torque @ 14 psi. I have been mastering the car for two weekends in a row with the boost controller off (stock boost is 8-9 psi). The first weekend my mediocre launches got me into 13.4. This past weekend into 12.9. I'm now consistent enough with my 2.045-2.095 60ft launches.
This next weekend I'll be at low boost 12psi... the objective is to find out how me and the car reach a consistent good launch and shift. Practice Practice Practice.
The car has a stage one basic package upgrade 2JZ-GTE, 5 speed toyota manual, HKS twin plate and R200 diff with aftermarket axles. 18" rims with NT 555 extremes 265 rear and 225 front. 5lug conversion and R32 brakes front and rear.
The goal is 11 seconds runs @ 14psi. So I must practice practice and some more practice.
Good Luck! Hope this gave you the idea to practice!!!
