Thanks man, just what i wanted to hear. The caulking stuff is what I got worried from...that stuff can deteriorate over time right? Would a full out stitch welding of the whole car sound good to you? The added stiffness would be good. Any cons to stitch welding a daily/track driver, any safetyconcerns?180fan wrote:No worries. I'm the same way. If you're going for a full all out clean up and replace-everything method, check out the madness that my local Glenn did on his s13 http://www.stillensucks.com/ . That's the way to clean and replace everything on an s13. If you are going to go after the caulking, yes, it would be a good idea to have some stitch welding done and some other bracing on the s13 before the car goes out to the paint shop.
Weather stripping btw will be the toughest stuff to get since enough of those pieces have been discontinued.
the car will be stiffer for sure if you did every seam. and dont be like everyone else and spot weld the chassis and call it seam welding. do it right, 1.5-2 inch of weld, 1-1.5 inch of gapnwmrkt wrote:also in regards to stitch welding the whole car...the car will have the same handling characteristics right? just woulb be "better" so to speak?
like this correct?LayNLow240 wrote:the car will be stiffer for sure if you did every seam. and dont be like everyone else and spot weld the chassis and call it seam welding. do it right, 1.5-2 inch of weld, 1-1.5 inch of gap
Ic thanks, so what your saying is weld some places and others places not? This is gonna be a street/weekend warrior car...what places do you recommend welding and not? It's just that "caulking" stuff in worried about...does that stuff deteriorate over time (what exactly do they do)? Anything I should do about it? (thats why im thinking of welding), or am I just speaking nonsense?180fan wrote:1. in a crash, unless there are points (like crumple zones) that are weak, more energy will be transmitted to the driver. So if you're going all out track car duty, leave stuff like the bumpers, the foam, and leave areas at the front and back normal versus doing everything. At least you'll be sure there will be some areas that will take that engery instead of you taking a good hefty sum of it.
2. check out what the names imply. Seam, think of the seam of your pants and such. Looks fairly continuous. Spot, in spots. LayNLow's post gives you further details on the distance the continuous seam should be and the gap between the seams.
