KingTurd »
https://forums.nicoclub.com/kingturd-u68620.html
Sun Apr 27, 2008 7:28 am
Greetings all.
I just purchased a cheapo manual boost controller from eBay. Relax, its only temporary till I get a much better EBC.
Anyways, the seller isnt all that great with responding to emails, nor were there any instructions sent with the item. I have built homemade MBC's before, but this one came with a wastegate "bleeder/breather" to relieve the WG line between shifts. That makes sense. What doesnt make sense is how to set this up. The kit comes with the actual controller, as seen here:
which uses a needle valve adjustment. Internals seen here:
Now, here is the so-called wastegate bleeder:
(nevermind those teeth marks, I was attempting to take that apart until I stopped when I realized that the barbs are in there with 10,000 ft/lbs of torque, or they are glued in)
On both the controller and the breather, the arrow points in the direction to the wastegate actuator. With this bleeder box, however, this is how the airflow looks:
The airflow going from left to right is severely restricted. Air still passes through but only a very, very minute amount. Air coming from the top passes cleanly out the right hand side. Now, if you hook up the lines according to the arrows painted on the stickers on the controller/bleeder, the top port on the bleeder box will be left open (maybe to vent into the atmosphere or rerouted back into the intake). It seems to me thats where the WGA line vents its pressure, but I am not quite sure the pressure will even hit the actuator with that setup.
Something tells me this is set up completely different than the old ball/spring controllers. My boost source is coming from the hotpipe a few inches from the turbo, and it will lead to the stock WGA on a t25 for a 91 redtop.
Essentially it doesnt bother me if I just got hosed, since it was like $3.99. However, I would still like to give it a shot if anyone has a suggestion on how to hook it up. Ive never had problems with MBC's before, but this one just seems strange.
Thanks in advance!
