How To install the iPod adapter (lengthy post w/pics)
coxcj
Car: 07 Nissan Versa SL HB Sapphire, conv pkg, audio pkg, sunroof, 5/07 mfg date, 6/2/07 purchase
iPod adapter installation tutorial (for SL models with Satellite) – most of the wording will be coming straight from the Nissan instructions that were kindly sent to me by TheOrangeChannel.
Parts: iPod gateway module kit (999U7-ST000)N-Bus Harness for iPod gateway (999U7-VT000)N-Bus Harness for SAT radio (999U7-VT001)
Tools used: Phillips Screwdriver (#2), Drill with 1/8” and ¾” drill bits, 10mm wrench
Vehicle Prep:1. Apply parking brake
2. Record radio presets (as the negative battery cable will be disconnected)
3. Make sure the car is in park (or first gear for the manual transmissions)
4. Turn ignition to off
5. Open hood and disconnect negative battery cable to prevent short circuits (the 10mm wrench is the one that fits best)
6. Remove the following interior partsa. Glove box housing
b. Instrument Finisher E
c. Cluster Lid C
Harness Routing:1. Disconnect the main harness and N-Bus connectors from the head unit.
2. Attach connectors of iPod gateway harness (999U7-VT000) to the head unit and main harness.
3. Route other end of the iPod gateway harness toward the iPod gateway module mounting location.
4. Attach the connector for the satellite radio harness (999U7-VT001) to the disconnected N-Bus behind the head unit. Wrap one piece of foam tape around the connectors.
5. Route harnesses into and along the side of the glove box cavity.
6. Loosely secure the harnesses to the existing harnesses with the small cable ties. They will be cinched tight later after routing the iPod cable.
7. Bundle the harnesses leaving enough room to connect the module
8. Take the ground wire taped off to the N-Bus harness and route up to the screw. I picked the screw that is holding the hanging pied in the picture above.
9. Using phillips screwdriver, remove screw, attach eyelet connector and tighten screw (ground wire not shown here – this was taken before I figured out where I was going to put it).
iPod Cable Routing: (the original instructions show that it should go to the glove box, but I chose to route it to the storage compartment above the radio. I think it is much more convenient for a driver to reach)1. Drill a 1/8” pilot hold roughly 20mm from the rear and left edges (assuming you’re looking at the bottom. See picture.
2. Open the hole with the ¾” drill bit
3. Start routing iPod cable from inside of compartment with DIN connector end (barrel shaped) down the hole behind the head unit (See picture in step 9 of harness wiring).
4. Place the split grommet over the wire and insert into the drilled hole.
5. Route iPod cable to the module mounting location along same path as previously routed harnesses and though the loosely attached cable ties.
iPod Gateway Mounting: (Here’s where I’m the most different from the original instructions. The originals show that you should route it to the outer wall of the glove box cavity. I couldn’t find a flat enough spot to do that, so I ended up putting it on the inner side closer to the center of the car in order to find a flat spot to tape it to.)1. Using the provided alcohol wipe, clean the bottom of the module and mounting location.
2. Attach the provided double-sided tape to bottom of module.
3. Remove the tape liner. Attach module to the back of the “AT” module. (See picture in step 9 of harness wiring).
4. Apply equal pressure to the module for at least 20 seconds. Let the module sit for 5 minutes to ensure good adhesion before applying any pressure.
5. Connect harness/cable to the iPod module.
6. Cinch all cable ties tightly and reassemble.
CodeRed
Car: 2008 Nissan Versa S MT
GOOD JOB!
Welcome to the tutorials section, you will soon see this on http://www.nissanversa.org/tutorials.shtml I just need a few things from you, please Email me. [email protected]
Eastval1
Car: Versa SL Hatchback
In steps 6b and 6c, how do you remove those pieces without marring them? Thanks!
coxcj
Eastval1 wrote:In steps 6b and 6c, how do you remove those pieces without marring them? Thanks!
Under vehicle prep, for 6b, I lifted the front lip with my thumbs to get underneath it, and then you just have to toward you and slightly up to get it to pop out. I've seen that some people have used a flathead screwdriver wrapped in cloth so as not to scratch anything. As for 6c, There are 2 screws (just above the vents) that once out will free the face of it to come right off. Just take it slow and you shouldn't have any problems.
Eastval1
Thanks for the tip, it's much appreciated!
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
bump for CodeRed to post in the how-tos.
Martin Roy
Car: Nissan Versa SL, CVT Transmission, White exterior/Charcoal interior, Technology Package, ...
Good job !
CodeRed
Ever Victorious wrote:bump for CodeRed to post in the how-tos.
im getting there chill been doing updates to the gallery.
shreqboi909
Car: '98 ej8 R.I.P 07 nissan versa/tiida
how much is it for the parts needed?!?!?
coxcj
$235 for the iPod Gateway and the two wiring harnesses (from the dealer).
mac4444
Thanks for the insstructions. Where did you buy the kit and how much did it cost?Thanks.
coxcj
see above
ordered from dealer, total was $235 (something like $251 with tax)
TheOrangeChannel
Car: Nissan Versa SL 1.8
Good job dude! Glad i could help...I hoped you received that set of instructions since my desktop fax at work has been known to spit the bid from time to time...
