blindbug »
https://forums.nicoclub.com/blindbug-u135134.html
Thu Jun 04, 2009 6:23 pm
Step 3: Running through the firewall
While there are plenty of spots to run wire through the firewall, including drilling a new hole and installing your own grommet, there’s a great stock location that will accept the thicket wire you will likely run (1/0 ga). If I can offer any advice here, just be careful, you’ll be working in a tight space with a razor blade, and sharp edges all around. Most likely, you WILL scrape/cut yourself on something, much less if you get too hasty.
1. First you need to identify where the grommet is. Crawl up under the dash and look up, you will notice that the carpeting ends about a foot up into the firewall and there is some under-carpeting that goes up into the dash the rest of the way. Feel/look a few inches to the left of the Emergency Brake bracketing and you will feel a budge about the size of a tennis ball with some wiring coming through the under-carpet, that’s the grommet!2. Get your bearings on where the wiring is coming out, grab your razor blade and start cutting around the grommet itself. There’s not a lot of wires running around the grommet itself, only through it, but be careful! I found the best ‘technique’ was to score a semi-circle around the grommet and then get my hands in there to pull at the carpeting until I had the grommet exposed. The under-carpeting is fairly thick, but it will come out with a few strategic cuts and some pulling and ripping.3. Once you’ve got it exposed, again get your bearings on how the wire goes through, grab your razor blade again and cut a ‘cross’ into the lower section of the grommet. I found using the razor blade to get through a few layers and then using a phillips screwdriver to push through was a good technique. 4. Once you have your screwdriver pushing all the way through the grommet, you can start feeding the wire through. You won’t need a hanger on this one, the grommet is nice and pliable, so you should be able to feed it through from the inside. Once you have a foot or (2) through, walk around to the engine bay and look behind the air box, find your wire and pull your desired length into the engine compartment.
