Yes, they are OEM s13 aero side skirts. No, you don't make holes on OEM side skirts. Holes are already there. You would need washers for front and back to hold the side skirt against fenders. Yeah, if you have side skirts, you will figure out easily.VietGQ wrote:are those oem sideskirts??? when using washers and bolts did u make holes into the sideskirts
He said ANALAZ89two4Tsx wrote:
If you have the skirts, you could answer your own question. Really, it's not that difficult. You don't have to do it like that guy ^. He is VERY anal about his car, and everything is perfect lol.
*Ahem*, KOUKI sides. You won't need to drill through the rockers. The two metal brackets up top go into the little push through plastic screws on the step panel.tEknoS13 wrote:Sorry for threadjack but this is the perfect thread for me to ask this:
I have NEW OEM Type X sides with all hardware and they have push on clips along the way, it appears that I will need to drill through the rockers. Anybody have any insight on this? Sure double sided tape might work but is it safe?.0
I installed them this exact way:VietGQ wrote:4lug how did u install ur sides looks really good!
I was lucky and found my skirts MINT off of a moderator on Zilvia and he included all the hardware with the skirts for an AMAZING price. The only thing 94_240sx forgot to mention was the two screws at the front wheel wells go into where the holes line up with the skirts. They're blatant and you can't miss them.94_240sx wrote:You need 2 thin metal brackets on top, 3 brackets under the car, 4 brackets and screws front and back. Believe it or not, it was harder for me to find original hardwares than side skirts. If you can't find them, just use zip ties, double sided tapes, screws, bolts and washers. They will do just fine. IMO, no need to drill holes on your car for OEM side skirts.
i have the same skirts and yes 4 lug hero is either thinking of the wrong ones or misinformed. the little plastic push clips do indeed go into holes drilled in the rocker. it also gets double sided tape along the top. if you don't want to drill holes though use the tape and a rivet or 2 and it'll be fine without drilling any holestEknoS13 wrote:No man you don't understand my 180 sides did not come with these brackets unless you made some. I have the 2 piece sides way different set up. Unless I miserably fail at understanding
These are the side skirts I have:http://www.j-imports.com.au/uP...2.jpg
Modified by tEknoS13 at 8:11 PM 7/26/2009
VietGQ wrote:where did u guys get the hardwares from
I emailed several places to locate them. I bought most stuff from eBay sellers located in Japan and the last bottom bracket from Panda Garage. Bottom brackets look like these and it wasn't easy to find them in good condition.AAV240sx wrote:Would you mind sharing where to find some oem hardware for your skirts? Or did you make those yourself?
Actually, I did mentioned them, but it wasn't correct. 2 screws for the front and 2 brackets and 2 bolts for the rear.fourLUG_hero wrote:The only thing 94_240sx forgot to mention was the two screws at the front wheel wells go into where the holes line up with the skirts.
