180fan »
https://forums.nicoclub.com/180fan-u3602.html
Wed May 12, 2004 9:57 pm
fuel filter is on your passenger side of the engine bay you can't miss it, it looks like a small metal cylinder. You can change it through #1. pull fuse for fuel pump and start car. run it till it dies. then uncap your fuel cap. Go back to your fuel filter and undo the screws on the fuel line clamps and twist the fuel line right at the filter. It'll take a bit of work to get off if it's your first time. Toss in new filter and fuse and put the key into position just before start to let the fuel run through the filter.
MAF sensor use brake or carb cleaner, not directly on it, but let the fluid run over it but not at high pressure since it's pretty fragile.
o2 sensor is on the exhaust manifold and has one green wire running from it. you'll need a 22mm deep socket with one side cut out (for the wire) to get the bugger out. that's bascially what the tool looks like for the o2 sensor. they do make them premade like that so don't think you've gotta hack up one of your sockets.
