how to install led tail lights for 2007 maxima
mike23g
Car: 1997 & 2007 Nissan Maxima's
intrested in putting led tail lights on my 07 maxima. i need to know how difficult is it to install them before i buy them.
jsmithsole
Car: 6th Gen maxima
It is really easy to do, you just need to make sure you get the plugs nice and tight and don't mix them up. I assume you are buying these:
What color car do you have and what color tails are you going to buy? I have pics of pretty much every color on every color Maxima when we did the first test fitting. To help give you an idea of what will look best. Not sure where you are getting them but get them from http://www.ezkoncepts.com he helped to get them made and i worked on the initial design of them.
As for the install, here's something I did awhile back:
mike23g
Thanks for the pics and info, but i e-mailed someone from ipcw lighting. who are sell these lights on e-bay. i ask him if i would need a load equalizers his answer was no. i see in you pic that you have one( i assume there is one on the other side too) so im confused with this one. By the way my maxi is winter frost white or pearl to some im going with the ruby red and if i do need the load equilizers can you post how to install them.
jsmithsole
Car: 6th Gen maxima
mike23g wrote:Thanks for the pics and info, but i e-mailed someone from ipcw lighting. who are sell these lights on e-bay. i ask him if i would need a load equalizers his answer was no. i see in you pic that you have one( i assume there is one on the other side too) so im confused with this one. By the way my maxi is winter frost white or pearl to some im going with the ruby red and if i do need the load equilizers can you post how to install them.
No you do not need the equalizers, I wrote that up before I had the LED tails and was just adding LED bulbs. The IPCW tails have them already installed...but if you do have LED's in the front blinkers (which I do) you would need them for the front bulbs.
Also not sure what price you are getting on EBAY but my the guy I mentioned above will match or do better. And you'll be supporting a Maxima member/enthusiast!
jsmithsole
Car: 6th Gen maxima
and here's the blk on wht
If you go red then you will look pretty much like stock which is nice as well!
