lybrian1 wrote:thxsome one esle told me to cut the parking light wires then strip the ends of all 3 wires and then solder them together followed by heat shrink. them repeat 4 more times. 2 pairs of + and -. the only problem i have with this is that the wires of the parking lights are really short i dont have to length to cut them then re-solder them
The personwho told you this is right. I did exactly this. Cut and splice. It worked out well. So when you turn on your parking lights, the LED strips go on.
Is your strip with a Red, Black and white wire? If so you will follow this pattern on the parking light wires. All should be the same color. Some cars have different colors, if so, then you need to get an electrical diagram of your car to know which wire is hot, ground and netual.
