Indeed!Nick 568 wrote:The back-up bulb type is 921.
http://www.v-leds.com/Exterior-LED/Park ... 9-1-2.html those are the bulbs I put in my Rogue. (and I believe the same ones Leo just swapped in)
There's a few people on this forum replaced them for led or chrome bulb. I have 92 leds dual color. They're white when on and amber when the turn signal is flashing. Of course for the turn signal it was the same story that I had to get resistor.http://www.v-leds.com/Exterior-LED/Turn ... 9-1-2.htmlalisyed wrote:Have any of you guys instal led parking/signal light for the front? I dont think its worth it becuase the original looks really bright and its likee leds!
post6393030.html?hilit=tint#p6393030Scooter71 wrote:I could not get the assembly off for the reverse lights. For some reason no matter how hard I pushed on that inside screw it didn't move an inch. I even tried tapping it with a hammer. NO LUCK! Any advice?
with that light, prepare for a tug of war lol. the foam pad on the light is stuck to the metal. i had to use a mallet on the studs to force it out. (dont hit to hard, or you will blast off the studs)
its almost as if the light has the sticky 2-sided foam to hold it on, aside from the bolts. just keep carefully pushing.Scooter71 wrote:Thank you kind sir, I will attempt this again this weekend. I'm till scratching my head on the serp belt removal But at least I'll push on that screw stud little knowing for certain that's how the dame thing comes off. Geeeezzz You think what I was changing here?? LOL
