How to install kouki s14 tails?
Dazzla
Is it just plug and play? I didn't get any harnesses or anything with it. Just the lights themselves...I can't seem to find a guide or anyhting online.
BrianHarte
Car: 180sx
I think it just takes 8mm nuts.They might be 10mm, but I think 8 sounds right.
No mods necessary as far as I know.
Dazzla
oh ok, cause i saw on the net something about needing harness and sockets??
BrianHarte
Car: 180sx
You may have seen that for the 180sx taillight swap.
Amtk240
Car: 1997 Nissan 240sx SE Red S14, and 1995 Nissan Navan 240sx Ruby Pearl S14.
It is plug and play. You will no longer need the side bulbs as they will be replaced by a simple "reflector" and you can use your Zenki nuts to put back on the new light assembly. I would also caution being gentle with tightening the new ones on as the bolts are not the best quality. When you take the Zenki Tails off you will see that they are held with an extra "tar" type sticky material that becomes stringy so use caution removing them as to not get that sticky stringy crap on your paint.
One of the easiest mods you will do!
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
Dazzla wrote:Is it just plug and play? I didn't get any harnesses or anything with it. Just the lights themselves...I can't seem to find a guide or anyhting online.
Send them to me and i'll do a write up on it. I kid, I kid....but seriously
BrianHarte
Car: 180sx
Amtk240 wrote:It is plug and play. You will no longer need the side bulbs as they will be replaced by a simple "reflector"
That means they are japanese lights.
USA had a light there, Japan did not.
Amtk240
I'm thinking of the LED Kouki "style" tails and that is what I based my post from. I didn't read completely into this thread. I just came into this thread with the, "I'll help you citizen!" superhero type attitude. Sorry....<stealthly exits>
captainfalco
Car: S14,MX83
Make sure you put enough goo on the corner lights. When I did mine, I apparently didn't put enough on and water would leak into my trunk. I fixed it just the other day.
Dazzla
yeah it was a peice of cake lol...pretty much bolt on except like you guys said the side markers are not used!
