HOW TO: Install Fog Lamps on your Versa (Not 56k Friendly)
COVersaSL
Car: 2007 Versa SL Sedan
evil200000000 wrote:I'm not sure which one is the low beam wire. Would you be able to tell me cuz i dont have a circuit tester and also how do i hook it to the battery? I got this kit.
The blue wire is low beams and green is brights. PS don't hook it to your battery!!
evil200000000
Car: Black Versa HB 1.8SL CVT
well one of the wire has to go to the battery. the red wire to battery and other end to the relay? is that correct?
evil200000000
I got my lights wired up; mounted. but it doesn't work. the LED switch inside lights up and turns green when I click it. (that's after I have low beam on). Do I need additional fuse to work b'cuz it's drawing too much power or there might be a loose connect?? Please help!! Thanks.
