How to install Floor light is car (LEDs Strip)
desi4you
Car: 2010 Nissan Altima
Can some guide me how to instal led strip in floor i have 2010 nissan altima thnakspls
DReed86
Car: Altima Coupe 2008 SE 3.5 White CVT
When you say s
desi4you wrote:Can some guide me how to instal led strip in floor i have 2010 nissan altima thnakspls
When you say floor what do you mean? The footwell leds? Or in the sides?
You will need: a strip from Oz ledsRed and black 16gage wire about 20-30 feet. a Rocker Switcha fuse holder and fuse with atleast 20-30amp
One red wire will go from the rocker directly to the pos. batteryOne black wire will go from the rocker through the neg. end of led and end at the neg. batteryOne red wire will go from the rocker directly to the pos. leds.
Its very simple you will have to run the power behind the glovebox and drill a whole in the edge of the engine (just plastic so no big deal)
Email me if you have any question. I did a bunch of leds in my car looks sick once you are done!!!!
desi4you
Thanx bro..
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
racinglineperformance.com has a kit that is plug and play for footwell lights, there's a few options including fronts only, front and back, activation with interior lights or with a switch. and you can get different colors
Mattv609
Car: 2009 Nissan Altima Coupe 3.5 SE V6 Azure Blue
Blackmobile wrote:racinglineperformance.com has a kit that is plug and play for footwell lights, there's a few options including fronts only, front and back, activation with interior lights or with a switch. and you can get different colors
yeee this is a good pick up, got it for mine and easy install... n the switch is nice n OEM look..either on or on with dome lights... n bill deff is a great help give u his direct # if have any numbers...
