how to install coilovers
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
tonetone23
whats up guys. i just got a set of coilovers foe my 2009 versa. i got the front one on but i have no clue how to do the back ones. can someone help me out. thanks
CodeRed
Car: 2008 Nissan Versa S MT
Jack up and jack stand the rear end.
undo the bottom bolts holding the struts in.
undo the top bolts holding the strut in. Remove the strut.
Remove the springs
Install in reverse order
Also.. Welcome!
tonetone23
thanks. but one more question the springs go in the same spot with the height adjuster?
biggie
tonetone23 wrote:thanks. but one more question the springs go in the same spot with the height adjuster?
Yes the height adjustment should be on the spring.
Pics of the coilover system would help too.
Riceball88
Car: 2011 Infiniti M37
Good luck with the install and please post pics! I'm contemplating coilovers and I'd love to see how yours turn out.
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
if i remember correctly you have to remove the 2 bolts that hold the torsion bar in place, which i think are the same bolts that hold the bottom of the shock... so once all is removed go into the back of the car and remove the little access tabs that lead to the top of the shock, undo that and then you should be able to remove the whole shock.... but dont forget that you will have to use a back up when removing the top, otherwise you will just keep turning forever... hope this helps...
Return to “Versa Technical Discussions”
