e_c »
https://forums.nicoclub.com/e-c-u14217.html
Sat Sep 03, 2005 9:01 pm
i would unplug neg terminal on battery, then connect all wires, any loose wires, INDIVIDUALY electricle tape up, and you will need a stronger ground, the stock one sucks, i used a 18g wire and ran it to a bolt on the shift boot area... youl see... then once everything is connected and elec. taped up.. connect the battery again, this should do the trick... the thing that seems to burn out the tcu is any shorts in the system caused by hot wires touching the wrong connections... good luck
