How to install cabin air filter in Pathfinder
BryanWSD
Car: 2010 Infiniti G37S Sedan
2002 Nissan Pathfinder LE 4x4
I know I saw a post in here on this, but I can't seem to find it anywhere (on a side note - it's very annoying that you can't narrow the google search to a particular forum).
Anyway, I'm hoping one of you experts can point me to a link with instructions on how to "add" the cabin air filter to my PF.
Thanks!
fueler
Car: 2 Nissan's
2 BMW's
i can help u out in SD where u at!
fueler
Car: 2 Nissan's
2 BMW's
oh wait, you are adding or replacing? the OEM cabin filter should come with detailed instructions
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
The 02 Pathy doesn't come factory equipped with cabin filters.Installing them is a piece of cake. I put in a set this summer.All you need to remove is the glove box. The air box is right behind it.If this is a new install, then you have to remove the knockouts.Then the filters slide in, one above the other.Have fun.
02pathfinderle
Car: pathfiner le 2002
QUOTE=Buzzman]The 02 Pathy doesn't come factory equipped with cabin filters.Installing them is a piece of cake. I put in a set this summer.All you need to remove is the glove box. The air box is right behind it.If this is a new install, then you have to remove the knockouts.Then the filters slide in, one above the other.Have fun.[/QUOTE]
so if my path doesnt have a in cabin filter i dont think , u can add one yourself is what your saying? just remove the glove box ? where does it rest and what are the knockouts?
i always thought the paths with stock cabin filters had it in the trunk on the fender side
BryanWSD
Fueler, I'm in SW Escondido, and yes I'm trying to add them new. It does not have a cabin filter now.
I take it for parts, I just get the QX4 filters for my model year, right? It sounds pretty easy. I think I'll go pull the glove box this morning and take a look.
BryanWSD
Found some useful info from the board.
Filter install instructions here:http://www.courtesyparts.com/i....html
Pics here:zerothread/289709
BUT, just got back from Escondido Infiniti and parts is telling me they don't have the clip, don't have a part in the system for it, and that it may need a door to go over the filters to properly seal the unit.
From the pics, I see a metal clip but no additional door. Anyone else actually completed this on their PF?
red det is slow hater
Car: faster than your POS
^^ the OEM filters already come with the clips. im 100% sure of that cause i replace them every time and i just throw away the old ones (the new ones are always stronger) and no there is no door, what you see in the second link you provided is the ends of the filters. There is one clip on bottom and one clip on top. Again, the filter comes with the clips. Curious - how much did infiniti esco quote u for the filter?
BryanWSD
Infiniti Escondido quotes $34.95 for both filters, but there was no metal clip in the box. He says I'm the first one to ever come in and ask how to do this.
