elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Thu Apr 20, 2006 2:19 pm
take the diff out and put the new one in
Sorry, Im no comedian so I'll stick to nissans. Anyway, you will want to do the following, in no particular order.
- Undo the axles from the diff- Undo the driveshaft from the trans. NOTE: In order ot do this, you may have to undo the center bearing bracket so yo ucan slide the driveshaft foreward.- PLACE JACK UNDER DIFF- Remove the 4 fasteners hold it to the subframe. 2 up front, 2 out back on the subframe. - Slide diff foreward and remove from car
