MikeS14240sx »
https://forums.nicoclub.com/mikes14240sx-u214.html
Fri Nov 01, 2002 11:12 am
stickgoat a few tips when you do your install. If i remember correctly, the instructions that come with the dual n1 say to mount the two pieces first then bolt them together under the car. Don't i tried that and i couldn't get the holes to line up between the two pieces. Just bolt it together off the car, it makes it easier to make the bolts tight as well.
Also slide the two rubber hanger pieces by the muffler off the rod hangers on the car and put them on the dual n1 rod hangers first. The rod hangers on the exhaust are longer then the rod hangers on the car so the rubber pieces are easier to line up.
Screw in the middle hanger that comes with the exhaust. Have a friend hold the end of the exhaust in place while you start to thread the cat. nuts onto the cat. studs. Then line up the middle hanger, just start thread the nut. then slide the two rubber pieces onto the rod hangers on the car by the mufflers. then go back and tighten the middle hanger nut and the two cat. nuts.
And your done!!!!!!!!! Now all you have to do is enjoy the heavenly note the car makes when you drive it:ylsuper
If you don't understand what i'm talking about now, once you start to do things the hard way you'll figure out what i'm talking about.
