how to install a CAS 92 Q
ejXa q45
Car: 1992 Q45 infiniti sliver
i need a little help on install a crank angle sensor on my 92 Q .i know how to remove it i just need to know how to time it and what ever anyone can tell me aboutit that might help me one this project .
thanks nice x-miss icons
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
youll have ot get yourself a timing light... Stick it in there so its close, leave the bolts kinda loose so you can still turn it a little, and then bust the timing light out and retime the motor...
Theres an article on Q45.org on how to retime the motor... It takes about 5 mins.
ejXa q45
i just put it in and did not time it but it ran until i wormed up .... i checked the ecu got code 17-34 knock and tcs .... whats up with that
Q45tech
The slot on CAS will allow the setting of ignition advance from -30 to about +15 degrees..........................it must be set at -15 [+-2] degrees for the ecu to function properly.
elwesso
2007 BMW M Coupe
ejXa q45 wrote:i just put it in and did not time it but it ran until i wormed up .... i checked the ecu got code 17-34 knock and tcs .... whats up with that
does your car have TCS?
ejXa q45
background 92 q 120,000 miles no cats . intake . new coils & plugs. new transmission
the car runs and it feels fine ..... until it worms up and then it has no power and then it back firesbut i don't think that the crank angle sensor is what is wrong with the car. i don't know what is happen.................. i need help......... i am a won-ta be mechanic i cant do his alone
i did not time it but put it back in the same spot it run well, better then it ever ran until it wormed up then run like **** what would make this happen?
Q45tech wrote:The slot on CAS will allow the setting of ignition advance from -30 to about +15 degrees..........................it must be set at -15 [+-2] degrees for the ecu to function properly.
i did not see any slot to advance timing ...unless i have to open it .......i got codes when i check it 16 - 34 . but maybe i am getting the knock code is because of the back fire
please help me..... please help me i need my Q back.... i miss her .
elwesso
2007 BMW M Coupe
jsut get a timing light, any inductive timing light will work....
ejXa q45
why would it run fine until it worms up ..... i just do not understand. its exactly when hit half way
and yes i do have tcs i though all Q do..... i have the button
