First, here is where you can find an FSM for your car:
http://www.zeroyon.com/index/content/view/24/47/
Second, you will need to order part number 8803 from MSD, or source a cap that will let you use an external coil. Possibly from Jacob's Electronics. If you do not already have a blaster coil or something like it, get one, you need it. You also need better wires for use with this system. Instructions for 8803 are listed in the instructions.
Wiring: Note - sources are EC-106 of the FSM for the 95 (all should be similar, but if you are uncertain, just ask), and the page of your instructions for General Import wiring.
Connect light red wire (lower gauge than heavy red) to the black wire with the red stripe.
Connect light white wire to the to the Light Green and Black wire after the resistor in the distributor.
Heavy red wire will be for power B+ to the box, and Heavy Black will be for GRND. I would HIGHLY suggest you fuse your MSD so you don't waste your money if you mess something up./
Orange will be to the positive side of your aftermarket coil, and the light black wire will be to the ground side of that coil.
The wire for Magnetic Pickup will not be used (the KA doesn't use a magnetic pickup). Also, you should not need the tach output wire. In most cases it has shown not to be necessary.
As with all wiring projects of this nature, do NOT use butt connectors, you want to use soldier, dielectric grease and heat shrink, or at least Tartan-44 electrical tape (don't use cheap tape!) Of course, as mentioned, I have an i.C.E. Pak box that I would entertain trading for this and whatever coil you have. Naturally, it would be straight up, pay our own shipping. The advantage to the i.C.E. Pak is that it has a primary trigger already wired to the box. This means you can just run a spark plug wire from your stock ignition to trigger the aftermarket box. This means no wiring. I hope that helps, and please let me know if you are interested via email.
