Ca18det240sxchk wrote:ok, they didnt really have n e instructions based on the fact its universal ****... so when they send instructions on the tach its basically telling me i need to hook it up to the distributor,,, uhm dont have one so... yeh... i need wire colors and detailed instructions por favor!
tachometer signal is on the small white plug beside the ECCS plug, it's the yellow/red.
As for wiring it...USUALLY they'll have 3 wires. Red, black and some other colour. Red is usually power, black is usually ground and the other is usually signal.
Are you sure absolutely no instructions came with it to tell you which wires are which on the tach and other gauges?
As for the oil pressure, gotta know if its mechanical or not first.
Your water temp should have come with it's own sensor, so you just need to put that either into the head, or in the upper rad hose.
As for O2, if it's narrowband, then you hook the signal up to Pin 29, it's a white wire on the ECCS plug. Or if you wanna hook it up to the wire in the engine bay, it's the shielded one in the middle, again, also white.
http://www.impactblue.org/cont...iringThat's the ECU pinout.
if your oil pressure gauge is mechanical, you have to tee it into a source, I don't know where cause mine is electrical. If yours is electrical, then you'll have a sender. The stock sender is on the intake side under the alternator. it's a small plug dealie that screws into the engine. You'll most likely need an adapter. You can get an adapter that can take two(basically a T) or just get an adapter for your aftermarket gauge. The thread pitch of the stock one is 1/8 BSPT (if memory serves me right..but it might not...)
