How to hold Stopper Nut in place while installing alternator?
eallanboggs
Car: nissan Q45
Trying to reinstall the alternatlor on Q45. It has a Stopper Nut(nut welded to a bent piece of steel flat stock) on the long pivot bolt. How do I secure the Stopper Nut to the alternator while I'm putting the alternator into position. I'm thinking of glueing it, but I know this isn't the correct method.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Hey, welcome to NICO.
There are several posts on this in IOM (Infiniti Online Mechanic, where this post should be). Trya search there.
Drake57
Car: 1992 Q45, 1990 Q45 (parts), 06 Sportster XLC, 85 XJ6, 08 4Runner, 89 Suburban 4WD, 75 Honda CT90
On my son's 1991, I used 5 minute epoxy with the alternator unmounted, using the bolt to hold the nut in place, waited until the epoxy started to tighten up, then removed bolt, oiled the threads and installed the alternator.
We did not have the OEM nut, since the person who installed the alternator before my son bought the car just skipped installing the nut to begin with. I suppose some mechanics have different standards.
Drake.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Double sided tape has been used also.
dsagers
Wrap tape around your finger, with the sticky side out. That will hold the nut in place while you start the bolt into the threads.
Raxephon
Car: '04 RX8...for the moment...
I typically use "sticky-tack" or "poster putty" to adhere it to the alternator until I can get the bolt threaded into the nut.
Keep in mind that this will only work if the pieces that you are using it on are clean, dry, and not too cold/hot.
