92sxCalifornia »
https://forums.nicoclub.com/92sxcalifornia-u101232.html
Sun Aug 07, 2016 9:34 pm
Here are a couple of things that might help NOX.
I failed NOX on stock S13 after doing all the regular things, EGR working, Sea Foam, warm engine, RXP, etc. Don’t want to take everything apart for a real de-carbon.
I always had a broken detonation sensor and passed smog, but I had fixed that recently. But does a working DET help, or hurt? A failed detonation sensor (code 34) does not trigger the MIL light, and the engine compensates by retarding the timing. Retarded timing helps NOX.
I passed the next smog test by doing 2 things. I pulled the detonation cable (actually electrical taped it to look intact) and I got aggressive with the timing, setting it at -15 with a timing light. Weird, Consultan reported -20, and the smog shop showed -19 (they check in CA). Whatever, it worked.
Anyway, maybe you can consider this for your NOX arsenal.
