frapjap »
https://forums.nicoclub.com/frapjap-u17700.html
Sun Aug 29, 2004 1:30 pm
The engine doesn't like to breathe much above 6000 rpms. Try driving it the way it is stock and attempt to red line it. At about 1k rpms short of the red line, you will feel it cut out and loose power. The only way this isn't going to happen is with a lot of work put into the KA. Its going to need a whole new bottom end: crank, rods, pistons, not to mention the valvetrain that can keep up and move as quickly as the greater amount of air you are displacing bu stroking the motor. You'll need some somewhat radical cams with overlaping durations, a much more efficient head and well...basically you're going to have to build the whole motor. Which, if that is what you're trying to do, essenitally rebuild the whole motor, is great. But I haven't heard of or seen anyone willing to devote that much time and money to accomplish this feat. If you really want a 'high reving engine' then fabricate a way to swap a Wankle application into the 240. That would be something neat.
