teg_autox »
https://forums.nicoclub.com/teg-autox-u2495.html
Tue Oct 29, 2002 6:26 pm
O.K. I can tell that not many of you race competitively becuase most suspension threads on this board say silly things like "giving a firm ride with out being to harsh" or "nice ride and not to stiff, and it looks cool lowered". There are many things invovled in the physics of handling. But a good start would be Koni double adjustable shocks $kaching$ custom valved for your car. And a cheap alternative to coilovers is the Ground control kit. And an absolute must is LINEAR rate springs, DO NOT GET progressive rate springs like Eibach, or sprints, or tenzo R, or whatever. They are all to soft, and when you have 2 or more spring rates per shock your car can be unpredictable and become unstable under cornering loads. Most lowering springs are made for street cars, coil-overs are generally designed with racing in mind. I Can maybe help more on this subject in the near future but I have not yet tried enough things on my 240's suspension. I am learning more with every car I work on, be it honda, toyota, subaru, or nissan. So far the best handling cars hands down that I have raced are the hondas. But I am confident that if I build it right my nissan will out handle my Acura any day. I have had very good luck with the KYB AGX's they seem to have very aggressive valving for auto-x and combined with the above mentioned GROUND Controls they can be very competive. BUT they will not ride smooth. If you soften the rear more than the front it can help on the street. I do not have any suggestions on spring rates yet, hopefully will know more soon. Also buy an extra set of 15" rims and mount RACE tires, probably the Khumo victo racers they are very nice, but will wear out if you use them on the street. Bushings, and strut tower are of lesser priority, unless your bushings are worn out, strut tower bars are just for looks, admittedly anything you can do to stiffen the chassis and isolate the suspension is a plus, but these tower bars are mostly junk, nothing will do as much as a good 6 point roll cage. Sway bars are good for body roll, which strut cars dont like, just keep in mind that a larger front sway bar is gonna increase understeer, and a larger rear bar will increase oversteer. Most auto-x'rs leave the front bar alone and only upgrade the rear bar, to help with rotation.
Sorry for the long winded response but depending on what you wanna do with the car this can be a very long discussion, there is way more to suspension geometry than I know of still.
P.S. did I mention that I hate progressive rate springs?
