EckOMaN2k wrote:Ok well i have a pair of 18's that are 7.5 inches wide in the front & rear, an the offset is 42. An im about to order some tein basic coilovers an from what i heard the coilovers can change the offset. But anyways how big of a wheel spacer would i need for the front and back to get that flush look, but not rub the fenders?
P.S with coilovers cant you adjust the ride height to your level?like i know my friend has a pair of coilovers on his s14 an he adjusted his to lower the car 4 inches.
Dystopia wrote:flush is all personal preferance. i personally do not see the picture that was posted above as near flush there is sill much to be desired.
this is far better 17x9 all 4 corners at a +15 offset
again why staggar sizes when you can fit 9j's at all 4 corners?
phatpat240 wrote:Not to steal this guys post but I had a similar question. I have a 97 se.I'm planning on getting a set of volk GT-C face 2 wheels in a 18". I was just wanting to know what offset to get too.I'm not planning on running coilovers,I'm just wanting a set of tein high tech springs w/ agx's.I want to run a 18x8 or 18x9 somewhere in that range.I just want something like a 245 in the rear.So what offset for me? And do I need to run a spacer to clear 26mm z brakes? Thanks alot guys
Dori Dori wrote:To me, this is flush. Perfectly.
[img]http://www.stillensucks.com/Project_Sil ... otos/5.JPG[/mg]
[img]http://www.stillensucks.com/Project_Sil ... otos/9.JPG[/mg]
