How to get rid of HICAS
Phaze1ne
Car: 1991 Nissan 240sx
I have a 91 240sx with Hicas and I want to know how I can get rid of it. I have an SR20 in it but I didn't put in the power steering pump for the HICAS. There is power steering, but only in the front wheels. Since there is no power steering for the HICAS, the rear wheels sway. Is there any way I can get rid of the HICAS. I'm interested in upgrading the suspension and maybe get into drifting, so I want it gone.
I also heard something about a HICAS diffuser. Can someone elaborate on this?
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
http://www.splparts.com/ has hicas eliminators... under silvia, rear-multilink
eddiec
Car: 91 S13
or rip out all the plumbing and get a non-hicas rear subframe. for the price of the eliminators you could really eliminate it and lose weight in the process.
btw i'd be interested in buying the rear rack and plumbing if you do remove it.
vvaffle
Car: 1991 240sx base hatch, 2009 WRX
eddiec, do you mind if I ask why you would want the rear rack and plumbing. Are you doing something where HICAS would be a decent advantage? And yeah phaze1ne, as they said, you can either get the eliminators to disable it or actually get rid of the whole thing.
Dori Dori
Car: Cars of course
There's a few ways you can get rid of your HICAS.
You can get the Tomei kit (not recommended)...it's little more than a couple washers and a computer to turn off the Hicas light. This kit can be copied by either getting your own washers (or welding the steering rack) and pulling the wires for the Hicas light. It's really a crappy way to get rid of Hicas if you ask me.
You can get the Border Hicas eliminator available from SPL. Looks nice but it's a little expensive for me. On the bright side, you can still adjust toe and have heim joints instead of rose joints.
You can swap the entire rear subframe for a non-hicas one. Too time consuming and difficult for me. Difficult in the sense that transporting an entire subframe is a PITA. Plus you lose your toe adjustability and replace ball joints w/ bushings.
You can also just get a Hicas eliminator bar from Kazama or http://www.japanesemotorsport.com.au/ I bought mine from JMS (link) and it worked great. I get to adjust toe and have 4 less bushings to worry about.
eddiec
Car: 91 S13
i just want it so i can rebuild what i have.
ralp2
Car: 1993 nissan 240sx se
i red your post and i was wondering what you did with the lines that go from the pump to the rack cause i just order a kazama hicas stoper and i should be getting it tomorrow you mentioned that it worked perferct on your car .i will really apreciate if you have any extra info or tips to get rid of the hicas .thanks and i hope to hear from you.
best regards
addisonblck
Car: 93 se mods soon to come
Sc300 1jz swap laundry list of goodies
to get rid of it as said before. either buy a regular subframe( better way to go imo) or buy the over priced eliminators.
now if you get an emliminator kit dont cheap out and just get the washers and call it quits. get the full bar kind. it should come with an actual bar to replace the rear arm and 4 screw type caps to cap off open lines..
but the best way to go is replace the entire rear end. -you'll get rid of extra weight -you'll save some money if you go grab one from the junk yard( like 50 bucks here)-it'll give you a chance to replace bushings lol-also with the hicas models there are certian arms that you cant use on your suspension because hicas takes the place of that there by eliminating your chances for correctly aligning your car if you lower too much.
but if you swap rears or put the bar in , find a way to get rid of the hicas light. i disconnected mine and replaced it with the change holder lol
o on another note. dont get rid of your ps pump or your steering rack. thats all im saying lol sorry if i under cut anybody.
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
or you could just get a rolling shell without HICAS and put the essar there.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
nifares240 wrote:or you could just get a rolling shell without HICAS and put the essar there.
This would be the easiest option if it's available....
240s are getting harder to find... in the hobby shop here on base, i put my car in there yesterday and started ripping it apart... (finally got this project going) and everyone was amazed to see one on the lift... Even the guys that work there say they never see the s13s anymore. When you do see one here it's usually rusted to pieces.. or multicolored... sometimes even both.
addisonblck
lol i have a hicas shell ive been tryin to get rid of for a yr.....
PyR0NiAk
addisonblck wrote:lol i have a hicas shell ive been tryin to get rid of for a yr.....
he wants non hicas
addisonblck
^ ya...i caught that..... i was stating that its funny how supply and demand differs in the different states......
thanks though
