how to get rid of crappy amp
Post all your Nissan electronics, car audio and stereo questions here!
240marcuSX
Car: E34 525i
E46 M3
the guy that i bought my S13 from put a crappy little sony amp UNDER THE STEERING COLUMN, so that it conveniently falls onto my clutch foot sometimes. clueless as to why he had this because the car has the stock speakers.
<- not an audio man, how do i get rid of this stupid thing, ill try to get pictures if i can.
nab911
Car: 93 Nissan 240SX SE
Get detailed pics of the wires and such going into it and i can steer you in the right direction.
240marcuSX
Car: E34 525i
E46 M3
alright, ill have to see if i can steal someones digital camera.
corn322
Car: 1993 240sx
maybe there's a sub under the dash.
really it should only have 6 or 7 wires on it.+12, ground, on, audio in, speaker out+, sp out-
MECPInstaller
Car: installing stereo systems and minor performance upgrades
Your headunit should already be able to power the speakers in the car, so why that amps there i have no idea. Somethign that small can't put much power out anyway. Find out if its a 2 or four channel amp. Locate which are the speaker wires and find the speaker wires coming off the head unit. See what he's done with them if they are just sitting out open. Cut the wires to the amp, and either remove them or wrap them up with electrical tape, keeping the speaker wires untaped, then extend them with some wire up to the center console and to their appropriate places on the head unit. Ummm if the situation is different tell us and i'm sure we can figure it out.
240marcuSX
Car: E34 525i
E46 M3
well i had the sony deck that he had installed, taken out, and i had my current alpine unit installed at circuit city (hey it was free.) and my alpine is running through the amp, because when i played around and un-plugged the amp there was no sound. no sound at all. :(
err.
Silvia2b
Car: 95 240sx se / 07 G35s cpe / 2009 G37s sedan (rear-ended R.I.P.) / 19 Q50 rs400AWD
Sony used to make a little tiny 4 channel amp the size of a pack of cigarettes. It could be a one of those, but it is really unneccesary, if you have a new alpine. Let's see it we'll help you get it out. Other wise it could be a small 2 channel that has all four speakers wired in paralell to the 2 channels of output.
240marcuSX
Car: E34 525i
E46 M3
im thinking the amp is about 8"x8".
Silvia2b
Hmmmmm. I'm thinking it is probably a two channel. how many output terminals does it have, (4, two Pos, two Neg)? if so then yup it is a two channel. Do you have fader control or does it just cut sound off when you adjust fader front to back? are their RCAs plugged in or is it High level input?
