i
onecrazyfoo4u wrote:They're just stock rotors and pads, lots of meat left on the pads, so it's not the screecher. It's a very faint sound, not nearly that loud, but I still don't want anything to be wrong with it.
Is it safe to switch rotors, say swap the front left and right ones? I mean since everythings settled in on each side, I wonder if that would cause more problems? What all should be greased on the brakes? All's I did was grease the slides under the rubber boots.
it is safe to switch left and right for stock
you should a thing metal piece (brake shim) between the brake pad and the caliper piston.
the grease should be applied to both side of the shim on all 4 brake pads
