how to get my idle down with my setup
yoki-yoki
Car: 89 240sx coupe (sold) present 05 cav.
SETUP
SR20DET BLACKTOPGT2871R .86Z32 MAFBC 264 IN/EX CAMSGREDDY INTAKE CAM GEARBC TITANIUM RETAINERS and ValvespringP2M ROCKER ARM STOPPERSNGK BKR7E ISIS POLISHED INTAKE MANIFOLDSARD 850CC INJECTORSFRONT MOUNT3inch ehxastROM TUNED ECU
ok so i recent got a motor with this stuff done to it and it idles at between 1500 to 1200 around there is there any way to fix this without screwing anything up or is it supposed to idle that high cuz of the cams thanks for the help in advance i search and cant really find to much
rc1honda
Car: 1992 240 sx
2007 BMW 335xi
2008 Honda CBR1000RR
I have HKS 264 in my car an i idle between 900-1100rpm. Your is a little high but not to bad. Did you try to adjust the idel screw on the IAVC. Let the car warm up and turn the screw on the IACV thats between the 2nd and 3rd intake runner i think, on top of the IACV.
If this doen't do any anything the you can clean the IACV or just try and seafoam the car.
Funny i almost have the same setup. What boost do you run and what kinda of power are you making?
shift_SRDETuser
Car: 1996 Nissan 240SX SE
rc1honda wrote:I have HKS 264 in my car an i idle between 900-1100rpm. Your is a little high but not to bad. Did you try to adjust the idel screw on the IAVC. Let the car warm up and turn the screw on the IACV thats between the 2nd and 3rd intake runner i think, on top of the IACV.
My tuner told me that all sr20s with aftermarket cams idle better at around 1000-1200 rpms do not know why??? It might die if it was only to idle around 800 rpm all the time?
yoki-yoki
not sure of horsepower but its tuned for 22psi and it at 15psi now ill try the idle screw and see if that helps thanks
