cdlong »
https://forums.nicoclub.com/cdlong-u11619.html
Fri Jan 13, 2006 8:26 am
why are you doing this first of all? if you're doing it for money reasons, it will take a long time to pay off the modifications with the money you save.
your best bet for the diff would be a J30 ring and pinion like you said or one from an S15 r-type, 3.69:1 i think. that's the only thing that will get you close to your rpm goal. but then your car would be dog slow.
other mods help mileage too. getting more power often happens because the mods make the engine more effecient. as long as you don't use the power to go faster, gas consumption will drop. i'm not sure where it comes from but my car usually gets about 30-31 mpg on the highway doing 75. i've gotten as much as 32 on 100% highway. the epa spec is 28 and that test is conservative so doing 75 should give you about 26 mpg. click my sig for a full list.
there's free stuff you can do like keeping your tires inflated to 32-35 psi, keeping the car cleaned out (hauling crap around wastes gas). you can also keep the speeds down, drive like a grandma, and shift at around 2500 rpm. that will probably help the most. also, if you replace your tires, get some with low rolling resistance, narrow ones with a high tread wear. if saving money is the issue, use regular gas, there's no need to use premium, the car runs fine on the cheap stuff. (at least most do, some people have problems when using the cheap stuff)
fyi, the s13 tank is 15.5 gallons.
then again, you could just sell your car and buy a CRX HF. my old roommate had one, it was fun to drive and got about 50 mpg on the highway. i doubt your 240 would be much fun to drive anymore if you did all that stuff to it.
