skydragoness wrote:I can vouch that a little toe-out on my car was not great for highway driving. I had to correct it way too much, as the car tended to wander a lot. Personally, i don't see it useful for a street-driven car.
Like everyone else said get better tires and the 240 will shine.
That's interesting... did you have enough positive caster to compensate?
Personally, I like my new setup better than when I had a little toe in... maybe i'm just stupid like mcrussell pants says anyone w/ toe out is...
previous setup:front: 5 degrees caster, 2 degrees camber, 1/8 total toe inrear: 2 camber, 0 toelowered approx 3.5"+ or so all around, just enough to scrape almost everywhere I go.
new setup:front: 6 degrees caster, 2 & 2.5 (damn alignment shop) degrees camber, 1/8 total toe outrear: 2 camber, 1/8 total toe inlowered to less than 3", slightly lower than sportlines.
turns feel 200% more solid @ the track & city driving. Much less snap oversteer... could also be the driver, who knows.
highway I usually drive between 70-90mph depending on traffic - noticed less wandering - I attribute this mostly to raising the car since I noticed it right after I raised it for a rally event and driving home (didn't get alignment yet... after the alignment, it felt even a bit better).
sure there's some wandering, but nothing more than I had w/ any of my previous alignments (experimented w/ different alignments every 3-6 months, toe-in, 0-toe, different caster, etc)...
sure, the inside of the front tires will wear a little bit now... however, I seem to be wearing the outside more so than the inside w/ my driving... again, my new setup seems to be evening this out for me personally w/ visual inspection of the tires.
*sorry for jacking this thread.
