How to get AGXs compressed enough to install?
altralosix
I'm installing KYB AGXs with Megan springs (figured I'd be a guinea pig and try them, spring rates look good) but the problem is, as you can see in the pic I'm attaching, the AGXs are too damn tall and the holes on my knuckle aren't anywhere NEAR the holes on the strut. Anyone have any advice on somehow compressing the spring/strut another 2 inches? My spring compressors are too big to fit in the wheel well, and I can't get a jack under the strut due to the control arm. What do I do!?
dousan_pg
Car: 1995 240sx 1991 infiniti q45 1993 nissan 240sx
rmove your front sway barthe spindle will drop downand it will be easy
altralosix
dousan_pg wrote:rmove your front sway barthe spindle will drop downand it will be easy
You're a friggin genius! hah, I can't believe I didnt think of that. Thanks man, worked great!
97ka-t
Car: 1996 Nissan Maxima
1998 Nissan Altima
I have the exact same problem at this exact moment with my GR-2s.. I'm going to try that
