How to get 400+whp from the s13 sr20det?
CYBEREAGLE19
Car: Computers,Cars,Music
Ok what do I need to do in order to get this 400 or more whp, I have heard its pretty easy, thanks for ur input
BuudWeizErr
Bigger Turbo, Fuel Management, Standalone ECU, Injectors, Fuel Pump, Exhaust, FMIC, BOV, probably have the head worked, but it's been done with a stock head though. I'm probably forgetting something......oh yeah, a Type R sticker :pface
89sxRCR
Car: destroying self esteem
a lot of $$$$$$$$$$ so get ready to pay...
CYBEREAGLE19
I dont care about money I just want to know what components
89sxRCR
you dont care about money huh. what world you live in? daddy paying for it?
89sxRCR
oh and for your answer (SEARCH FOR IT)
89turbocivic
Car: Cars
This may give you some info:You need some kind of adjustalbe ECUI would say Apex power FC is a good start. Or you can go standalone with a SDS, Haltech, TechII, or Motec.You will need larger injectors. Atleast 550 CC (right?)If you go standalone then you don't have to mess with the MAF upgrades. But if you use the power FC you will need a MAF meter that can meter that much air. Larger Turbo:I come for the Honda camp and we use somewhat big turbo's but The SR engines make good power with moderate size turbo'sA T3/T4 with a .63 AR, stage III wheel, and a 50 trim compressor would be a good size to go with. Also make sure you fuel pump can keep up with your demands!Keep the A/F ratio alittle on the rich side. I am guessing 11.5:1-12:1 area. You'll meed about 20 psi with a stock Engine to make your HP goals.But hey don't listen to me I am new to this too! :D I'll let you know how it turns out.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Get a Z32 MAFS
mattback
Car: being a big f'ng ricer
holy cow. turbo civic did it right on the dot.don't forget. greddy intake manifold (good for 10-15whp after 6000 rpm)if youre going to do the t3t4, you might as well hop it up to a stage 5 wheel and get an equal length manifold. I used to be a believer in the log manifold and it is excellent also, but for maximum power and efficiency just go ahead and do the ENjuku turbo kit. Its proven. (i dynoed it and the jgs side by side).
also, for 400whp, you will want a larger fuel rail and injectors. whether you go top feed domestic oring type or you hop up to the man fuel rail and the 860cc sard side feeds ( stock rail just ain't large enough)
I noticed you live in florida specifically orlando.
The shop i work at, Secret Services, has first hand experience tuning stock motored SR's to very high horsepower levels. email me - [email protected] if youre interested in helping your baby haul ***
TrueSlide
Car: Stuff
89sxRCR, stop being a ***, just cause he doesnt work at the local McDonalds like you do, doesnt mean he can't come up with enough money to get what he wants.
TrueSlide
Car: Stuff
Just cause Dees doesnt post anymore, is not a reason to grow balls and think you will fulfill his place.
I H8 UR DSM
89turbocivic wrote: Atleast 550 CC (right?)
the start to max out 'around' that level, might want to go with 740cc's (72lb), or bigger
S14lover
TrueSlide wrote:89sxRCR, stop being a ***, just cause he doesnt work at the local McDonalds like you do, doesnt mean he can't come up with enough money to get what he wants.
DAMN dude......damn:ylsuper
89turbocivic
Car: Cars
Matt As far as going with a stage 5 wheel I would rather not use a turbonetics turbo. I have heard of too many of them failing/leaking oil from the start and I can get T3/T4's a bit cheaper then turbonetics. Has anyone used a T3/60-1 turbo's on the SR's? I have seen these turbo's make awsome power on Honda's. (of course they don't spoll till 5K so maybee they aren't partical for SR.
89sxRCR
Quote »89sxRCR, stop being a ***, just cause he doesnt work at the local McDonalds like you do, doesnt mean he can't come up with enough money to get what he wants[/quote] my little sister could think of a better flame than that, jizz mop. Lets ask him how much he has to spend, dollars to hoes (ur mom) that hes just a scc reader whos 16 and daydreaming. The local mcDonalds beats selling ur pimply arse out on the street, so you can earn $$ to fill your face with crack for you and ur trick daddy. Iv seen enough of these questions to fill ur moms labia with, (yes that many) so i can be an ***.
89sxRCR
ps. I forgot to mention :you suck balls
TrueSlide
Car: Stuff
89sxRCR, I would say good come back, but it is evident you suck at trying to flame, it sounds like you are trying to be like dees and s14, but sorry your attempt failed, I guess that could be due to the fact you spend all your time in the freezer of mcdonalds beating off over the SR Pic in the Superstreet magazine. Sure I guess you can be a ***, after all the beating from you parents you took after the countless times you were caught fondeling you sister, you sick f*ck. Due us all a favor, go OD on heroin, and drive your ricey POS honda off the nearest bridge. Oh ya try to go as fast as you can, the faster, the more we can enjoy it :) The reason I tell you this is because its evident you are not sh*t, but a little punka*s poser that is trying to be a attention wh*re.
It seems like your balls grow alittle bigger each day, but sorry they still are about the size of raisens, boy. You might think you are a man b/c you constitanly go down on the 60 yr old wh*re strung out on more drugs then you have had cocks in your arse. But sorry to disappoint you that doesn't make you a man, neither does tieing your mom up and anal banging her till your balls fall off, so you might as well stop that. Oh ya, screwing sheep doesnt either. So just realize the fact, you will never be a man, you will always be a fairy that that hangs out at the local retirement home, thinking you are "thugged" out while you "bang" all dem "hoes".
It seems like you have alot of anger. Maybe because your parents hate you( I dont blame them, I couldn't stand to have a ****head son like yourself.)
So you best bet, go kill yourself, make the world happy :)
Fuggin Terd tapper
TrueSlide
Car: Stuff
P.S. I forgot to mention, Your girl can give the best head. Remember that next time you kiss her.
sapix @ RHIT
I get really sick of reading this sh**, keep it in the ring guys
sillbeer
Car: cars and outdoor stuff
Why doesn't someone lock this thread. This is really stupid having kids calling each other names. Grow up...
89sxRCR
trueslide would never venture into the ring; his name implies the type of lubrication he applies to his pie hole so the garbage man wont throw away his house on trash days. Now class, lets examine the weak points of his "flame."( I see i have gotten him mad enough to flip out)Quote »good come back[/quote] why thank youQuote »it sounds like you are trying to be like dees and s14[/quote] actually im not, and i sound nothing like them. try going to the ring to find out, ya little dingle berry. Quote »Superstreet magazine[/quote] nah man i dont subscribe to your magQuote »go OD on heroin[/quote] kinda copied me there that time, trying to sound like 89?Quote »The reason I tell you this is because its evident you are not sh*t, but a little punka*s poser that is trying to be a attention wh*re.[/quote] hmm. actually i just enjoy ripping on dumb newb questions, your the one whos wetting his depends.Quote »It seems like your balls grow alittle bigger each day,[/quote] you looking at my balls? meat gazer!Quote »You might think you are a man b/c you constitanly go down on the 60 yr old wh*re strung out on more drugs then you have had cocks in your arse.[/quote] you mean your mom? yeah shes nicce.Quote »It seems like you have alot of anger[/quote] look in the mirror man.Quote »P.S. I forgot to mention, Your girl can give the best head. Remember that next time you kiss her.[/quote] man, have some respect for your mother! she gets very upset when you talk about her that way. Go to the ring if you want another beat down , astroslide, otherwise your just another silly queer who CANT flame. :) ps. you never responded to the fact that the newb who started this thread most likely doesnt have the $$ so why bother talking about any of this... Oh yeah so you can have something to do friday nights (instead of your right hand)
89sxRCR
Quote »I get really sick of reading this sh**, keep it in the ring guys[/quote] im trying, but when guys like trueslide start sh*t, you gotta respond.
I H8 UR DSM
grow up.
89sxRCR
:confused: he wants to play outta the ring so be it
89sxRCR
this whole thing stemmed from him saying i had no reason to question the thread starter... I am saying that this is another hypthetical newb question that doesnt need to be answered, cuz this guys just dreaming. He brought the fight to me, not the other way. If the thread starter would kindly just pipe back in about wether or not he plans to actually do any of this or has $$ of ANY kind to spend on his car, that would end the whole "discussion"
ahhsk
Car: Road race yamaha
Quote »I am saying that this is another hypthetical newb question that doesnt need to be answered[/quote]
what an ***, i had the same question and read the post with the hope of getting some good info. this use the search crap is being played out. if you have the time to chime in to say use the search, add some NEW info that an old out dated post may not have. also I thought that the pupose of being in a forum community is for communication, person to person, not person to search engine.
I have the same question as a matter of fact, just sold my E 46 m3, and although that may be hypothetical in your eyes as well, its reality in my check book, so stop hating, sit back, remove the butt plug, and shut the f^.
89turbocivic
Car: Cars
Thank you ahhsk:I bet if you would do a search for the word search you would get a crap load of relpys! :D A search function does no good if there isn't any info to search for.
Justice
Car: turbo's
ok stupid newb question? if people didnt ask the same questions over and over the board whould seem realy dead. come on guys. when you see "what exaust should i get" why do you click on it? if its to flame newbs than your a prick. i click on it to get more research on products. come on people you "pro 240" guys who are going back and forth in a message boards seem stupid as ****. after all. fighting online is alot like the speacial olympics. even if you win, your still retarded.
-Justice
TrueSlide
Car: Stuff
89sxRCR, now you are trying to be like K Car, even though you can not do it right, you chop up the remarks to have a attempt to flame and to make other readers lose the point of the orginally unedited quotes that you messed up. Give it up stop acting immature, the reason you try to flame in here is because no one pays attention to your posts in the ring.
If you hated what someone posted, do us a favor, don't respond, you only show you ignorance through the limited vocaulary you have aquaired throughtout your 10 years here on earth. Stop consuming space on the board with your pointless posts, flaming someone for something that they don't know, and something you don't know about either makes you look really dumb.
The thread what takes a SR to reach 400+ HP, and personally Iam kinda interested, I know a big turbo, but what turbo would be the best and produce the least lag compared to other turbos in its class?
89, no one is trying to be like you, people tend to want to relate themselves with people that on a higher intellegence level then you, and you sir are way below the bar. So like I posted earlier, just kill yourself, we will be so much better without you.
And Iam sorry to everyone for ruining this post, I just can't stand to see someone harass another member just because they do not know something that in recent posts were not explained in great detail, can't we all just get along and help each other out? I mean come on, we all drive the same car. Lets hate something worth hating, like Towel heads and hondas.
TrueSlide
Car: Stuff
Also I never said that, I just said stop being a ***, because thats how you are acting. Who cares how he gets his money, if he gets it, he gets it.
