CoastyAV8R »
https://forums.nicoclub.com/coastyav8r-u31435.html
Sat Dec 03, 2005 3:39 pm
I haven't been able to get any heat out of the heater and having ran the diagnostic on climate control system with no faults found, I want to look at the heater air mix door to see if the posts are broken. The FSM shows it's behind the center console but it doesn't give any info on what to remove to get access to it. I assume the stereo and possibly the climate control panel need to be removed. Having never done that, is there a trick to it? Can I check the door posts any other way? Thanks in advance.
Pat
