Chuck Tribolet »
https://forums.nicoclub.com/chuck-tribolet-u120862.html
Tue Jul 12, 2011 7:32 pm
I've gotten started on this over the last couple of days. I'm going to collect notes in this thread, and then put it all
together with pictures in a nice how-to thread when I get done.
I'm using the 4x4 parts split bushings. I had a spare upper trailing link with shot stock bushings to experiment with.
Step 1 was to get the metal insert (the bit around the bolt) out of the stock bushings. I chucked the trailing link in my vice, with the insert pointing down. I put a bucket of water under it, and fired up my MAPP gas torch and blew the
flame through the center of the insert until the rubber melted and the hot insert dropped into the bucket. The rubber will catch fire just before the insert drops out. Note that your are playing with fire. Just outside the garage, I had a garden hose with a spray nozzle on the end, and the hose bib turned on, just in case.
Step 2 is to get the outer metal part of the bushing out of the trailing link. I used my Bosch reciprocating saw (everybody calls these "Sawzall", but that's Milwaukee's trademark) to cut ALMOST all the way through the outer part. You don't want to cut into the trailing link because that will create a stress riser. First I cleared the remaining rubber away so there was a gap about 1/4" wide to bare metal, and I cut. Cut a little, look, cut again. When you look, check both ends and the middle. The blade is important. I started with a Bosch carbide blade and that didn't work well. Then I tried a Lenox 6" 14 tpi thick metal cutting blade (hey, effectively, you are cutting a 2" piece of metal, just not very deep). and that worked well. Have some spare blades. Keep the saw foot against the trailing arm, otherwise you are just vibrating the saw and not cutting well.
Once you've cut ALMOST through the outer part (ALMOST means all but the thickness of a Coors can), you can tap the
outer part out with a punch. Tap one side, then the other, keep alternating.
That's where I am -- one upper trailing link ready to go. Next step is to check the junk yards to see if I can find an upper trailing link. I'd really like to have one set of new arms ready to go before I jack the truck up.
One more thing: the melted rubber is really sticky stuff. I'm going to have to find somebody to run the camera as I don't want that goo all (or the general road grime from under the truck) all over my Nikon.
